kobrien
Looking for what the stock (factory) limiter strap setting is for a 2007 Apex RTX. How many holes are exposed under the fastener.
Trying to get back to stock so I can set to some of the recommendations on this site. Thanks
canapex
There a total of 4 holes in the strap.Two of the holes should be showing.That's how mine came from the dealer brand new.
vmaxx05stud
i think its the 2nd hole at least for mine it is stock.
Mine was set right in the middle. I beleive 1 hole showing on each side of bolt. Could you give an update on how it handles for you if your raising up one hole. I talked to Scott Bergstrom about this and he's against putting anymore weight than neccesary on the already heavy front end of these sleds. Premature wear on bars is one issue he thought could result. I might try front shock pressure increases firtst for more positive steering, and to still have little darting.
Ported Hornet
vmaxx05stud said:i think its the 2nd hole at least for mine it is stock.
Your sled has a totally different skid. Your settings will not help him.
Merry Christmas
