stock secondary wrap
jminor1
ontario
can someone tell me what the stock secondary positions are? I'm taking mine apart to put in the washers and noticed the helix is at 3. I have'nt pulled it apart yet but in another post everyone was saying 1-6. Mine is an 05.
pink spring this sled only has 60 miles on it I just pulled off the secondary for the first time. I was looking for the stock setting. Its definately not 1-6 but is that what everyone runs?
03-05 rx1 pink spring 60* stock secondary setting
hope this helps its in the tech under stock clutching.
run mine 2 and 3 50 degree with stock spring. like the faster out shift pulls alot better. decrease of eng. braking. lose a little backshift but more than enough power pulls you through. lowers rpm a little for mpg.
last year
2 mile long road in up michigan snow covered hard pack and 3" snow on top
60 degree =109 on dream meter
50 degree =124 on dream meter
40 degree =134 on dream meter got 1 foot of snow not enough back shift so ran at 50 degree with out a problem kept around 10,100 rpm
I tried the washer trick this weekend and it would stick the secondary open once and awhile. Would 50 degrees help that?
