LazyBastard
04/05 have different spring rate from 03. 03 had multi-rate crazy springs.
welterracer
I thought 04s had 2.1 strait rate springs?? can rememeber how i heard this!!
rx1familyman
Question - has anyone noticed when using the straight rate spring(that is a stiffer rate) that at high speed, threw small chatter bumps your control seems to fade away?
LazyBastard
The WARRIORS have 2.1's.
welterracer
Yep.. I knew it... Ya wouldnt think the warrriors would be that much different than the standard rx's!
Lazy would you suggest i go to 2.3 or 2.5 springs with my 13mm sway bar?
LazyBastard
It depends on how stiff you want it to be. Matter of personal preference. If you feel that its sufficiently spongy now to warrant going up in spring rate, probably would make sense to go two steps to the 2.5's.
welterracer
I guess i will try the bar first then go from there to the 2.5s if still not enough!!
sledheadgeorge
- Apr 28, 2003
- Which one? I have 6
Anyone know a good place to get the 2.5's here in Canada??????
Stormbringr1
Thanks everybody! I appreciate it!
Convert
- Apr 14, 2003
- Lakeville & Nevis, MinNoSnowta
Hey Stormbringr1 where do you live? I'm in the south metro
RTX Meirda
RX1familyman:
I think that people think that these heavy springs make the sled boumce along the trail.
As everyone knows, even though the frt end does not feel heavy in the steering......it is none the less very heavy!
My sled still rides like marshmellows even with the 2.3's. My SRX springs acted like bricks on the trail....my friends would ride beside me and say "the suspension does not move!"
It felt great to me and handled awesome!! What were the spring rates on thw SRX with the ohlins?
I bet they were were greater than 1.9's and remember the RX1 is a heavier sled in the front.
LazyBastard
SRX Ohlins was 2.7.
RTX Meirda
Stormbringr1
Convert said:Hey Stormbringr1 where do you live? I'm in the south metro
Just up 35E from ya, Convert. Eagan.
LazyBastard
Maxximum Performance (www.maxxperf.com) has them up to 4.3.
