Jory
- Mar 20, 2016
- Alberta
- 2007 Phazer MTX SC
I've been through the motor a few times and everything is tight and secure.
I am working off memory here but is there a pressure sensor on the top of the throttle bodies that 1 or 2 small vacuum lines are attached to?
Jory
- Mar 20, 2016
- Alberta
2 pressure sensors and each have a line going to the TB.
Sent from my iPad using Tapatalk
Try unplugging one at a time and see if it changes? It will thro a code but it will not hurt anything.
Jory
- Mar 20, 2016
- Alberta
I have tried that.
I have tried that.
I would love to help more but I am at a loss. If it was closer I would be able to help more. Send a message to Cannondale, he had one of these sleds and still may have one.
Jory
- Mar 20, 2016
- Alberta
I appreciate the help.
turboapc
- Dec 18, 2014
- Finland
- Other
- phazer
I think you need to test fuelpressures. Maybe bad pump or fuel regulator..i quessing pump..
Lähetetty minun Metal laitteesta Tapatalkilla
Jory
- Mar 20, 2016
- Alberta
I've already pressure tested the system.
turboapc
- Dec 18, 2014
- Finland
- Other
- phazer
maybe you can write a list what you have done already
plugs, coils wiring harness, fuel pressures, compression, timing, half ccompression system is working
fuel nozzles not junked and clear. timing also meausured from camshafts not from sprockets, chain is not too big
and if the basics are okay, friring, compression, timinf, fuel. it has to be fuel controller
Jory
- Mar 20, 2016
- Alberta
I have tested every sensor and have looked over everything multiple times so I'm guessing the ECU was damaged when the harness burnt up. I was going to use my standalone for piggyback fuel as the GEMS are pretty raw but at this point I might as well ditch the factory management and go full standalone.
What is battery voltage while cranking? Thinking weak spark. Also could be pickup coil. Or simply a bad connection at ecu. I assume you have done a compression check?
