stretching to 144"
raginyamaha
Waterford, wi
2013 xtx
Well i think the nytro is going under the knife this winter for a stretch. Going with oft tip up extentions and 1.5 intense i think. Do the shocks need to be revalved? do the springs need to be changed?
I would suggest adding some wheels at the back or you will burn sliders where the tip up is.
Are you already running your spring and shock near the stiff limit? If not I'd say give em a couple clicks and try that.
