birkebeiner
- Jul 27, 2009
- Norway
- Norway
- 2015 Yamaha SR Viper X-TX
As I ride quite a lot two-up together with my girlfriend, I need firmer rear shock for the skid. The stock shock is buttom-ing out too often
Any suggestions anyone? Have looked for Öhlins but I haven't found one that fits the Mountain skid
Ding
- Dec 21, 2004
- Howell, MI
- Black & Blue
Which skid?
birkebeiner
- Jul 27, 2009
- Norway
- Norway
Don't know the name of it, but it's in my 06 Vector Mountain
Handy
- May 12, 2005
- Anola Manitoba
- 1983 Bravo, 1988 XLV, 1991 Pazer II, 2005 Vector, 2006 Apex Super Charged, 2017 Viper STX DX 137, 2018 SR Venture DX
I would see if you can get specs for new Nytro MTX air shock. In the pictures that skid looks the same as yours without the springs. Air shocks tend not to bottom as harsh as springs. Just toss your springs if the specs are the same.
It sounds like you need stiffer springs to support the weight ,not a stiffer shock.
birkebeiner
- Jul 27, 2009
- Norway
- Norway
Where can I get stiffer springs?? I have already the springs on max stifness.
yamaha makes different springs.You could make some spacers or buy some from hygear.Her's a link to check out http://www.ty4stroke.com/viewtopic.php?t=88173
birkebeiner
- Jul 27, 2009
- Norway
- Norway
Thanks, will try this out!
One question though... when you stiffen up the spring, doesn't that make the rebound harder/faster, as I assume these shocks doesn't have a rebound adjustment..? And all you get with stiffer spring is a very "jumpy" back end?
With a better shock you get a firmer damping and a plusher ride?
I'm not a suspension specialist, so just wondering...?
No you don't get a bouncy ride with the correct spring and right ride height.You get a moother riding sled all around.
Right now with your sled saging all your low speed shock travel is gone so your riding in the stiffer part of the shock so the small bumps you hit it jars you rather then soak them up.
birkebeiner
- Jul 27, 2009
- Norway
- Norway
Thanks! Make sense to me
Will try the fix on the link above you sent me...
Again, thanks mate
Again, thanks mate
