Studs 137
Kenzie
Ontario
Canada
Viper ltx se 137 turbo
What's out there an what are you guys running for studs on a 137? Stud boy pro lite backers looks awesome let see what ppl are running
Woodys gold diggers 2 double backers followed by 2 singles. 144 I believe
1.5" studboy power point studs, this is 160 studs, this track is coming off soon and going on the market and putting on a new track with 1.63" triggers, 3800 miles on that track and studs and it held up awesome!
Bleed Yamaha was that your own pattern or what template did you use an how many studs is that
No pattern just eye balled it and I believe there is 144 actual studs. I started with just the double backers every other row 96 studs than added in the round ones the next year.
that looks awsome. im a fan of keeping it down the center. ive always used single studs. is there much more to drilling the track for doubles? do you use the backer as a "template"?
Yes I hold the backer in position and mark the holes and drill away.
I have studs down the middle of my track, when I bought the sled it came with them... problem is i wish the track would come loose in the corners. I find the 137 with studs pushes but don't know if I should take the studs out or not? I would definitely prefer a sled viper that corners well rather than hook up when I squeeze the throttle... thoughts? Should I take them out? Does the skid push less without studs?
I would recommend putting some aftermarket skis on! I put a set of C&A TRX's on last season and what a difference! You will not be worried about pushing any longer, and you still get to keep your traction!
Sent from my iPhone using Tapatalk[/QUOTE]
I have a set of curve xs skis, they are a huge improvement over the stock skis, but probably not as a agressive as C&As
i have 96 studs similar to bleedyamaha's setup without the singles. Poly doubles seem to be holding up and they are light with woody's 1-3/8" studs. Love it so far. With the turbo it hooks up just fine and doesn't push in the corners with the stock tuners and 6" shapers on the inside, 4" stockers on the outside.
