bigcountry
I put studs on my 04 warrior last yr and by the end of the yr the studs had ripped apart my header... Wasn't very happy about it.... Is there an easy fix?? I thought drop brackets but I didn't realize you had to move 2 mounts... Anyone have an easy or alternate fix??
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
Old hyfax! Cut the mount groves off so you have a thin strip left! Rivet to the protectors! Mine are about 3\8ths thick a foot and a half long! Mounted above the top idler to stop the track from slapping the header!
HOMEHARDWARE65
I have had studs in mine since it was brand new with no mods to the suspension or anything and i havnt had a problem
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
Me either with Woody's Megabytes, 1.325's .
I'm guessing his studs are longer or he runs his track looser than spec..
bigcountry
The studs are 1.325 I will have to check the tension on the track.
Fourcam281
I think hard braking makes the problems worse... so don't unless you need to!
mikeinchicago
I'm having same problem on 03 rx1, I'm thinking of doing what Sasquatch did with the old hifax, any other advice
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
All three of mine are studed also with no issues. Track too loose or studs in the wrong places?HOMEHARDWARE65 said:I have had studs in mine since it was brand new with no mods to the suspension or anything and i havnt had a problem
