zeke66
Going to put Ulmers Stage 1 clutch kit in and I was wondering if the track being studded or, not studded, makes a difference with the weights?
dirkdiggler
Suspended
traction is the key to any sled regardless of weather it's clutched or not. If you put more power to the track you must find a way to stop it from breaking traction.
SledFreak
- Feb 7, 2005
- Ontario. Canada
dirkdiggler said:traction is the key to any sled regardless of weather it's clutched or not. If you put more power to the track you must find a way to stop it from breaking traction.
I agree, but for some reason Turks seems to make it work without studs. I guess a bigger lug is required...
dirkdiggler
Suspended
SledFreak said:dirkdiggler said:traction is the key to any sled regardless of weather it's clutched or not. If you put more power to the track you must find a way to stop it from breaking traction.
I did say find someway. Didn't say studs becuase your right people like Turk use a Deep lug track.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
In speaking to Turk one of his comments (paraphrasing) is the "tractoring" away from the line...seems like he/they run differently than some of us...
Wouldnt clutching for deep powder be different then hardpack as far as weights are concerned?
dirkdiggler
Suspended
I think they race on Hard packed snow.
Turk
Tech Advisor
For snow i set up the clutches to really load the motor hard at engagement & let rpm,s climb. This means 4kish rpm engagement & rpm,s starting real low.For studs you don,t load the motor as hard & let it free wheel a little more at engagement.
eg...on snow engaement at 4k.
rpm,s start at 8-8200 rpm & climb to 8900 rpm at full throttle.
For a picked sled higher engement & start rpm,s about 8500 & let em climb.
