kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
I am still getting the occasional stud rub, primarily because the ZX2 shocks were shot last year and I bottomed out a few times more then normal. However what is a good solution for this with the ZX2? Just add some 1/4" to the stud protectors?
I run a cobra with 1.45" studs up the middle. I took the shocks out and cycled the suspension and I can't see how its even possible to hit the exhaust?
I do run the track a little looser then spec with the extros but not terribly loose. (about 3/4" sag when the rear is lifted)
