zquick1
How many studs are you guys running on the RTX my dealer said 96 down the center is enough on a 1.25 track.Doesn't seem like enough on a 150 hp sled
apexer-4-06
144 woodys gold diggers 1.325,, love it
Highmark
144 1.450 woodys gold diggers down the center. The tunnel protectors mount by light aluminum brackets. Take a pry bar under the tunnel protectors at these brackets and bend them out slightly (1/8-1/4") Jam a rubber/wood/plastic block in that gap so they cannot collapse. Take a rubber mallet and lightly shape the exhaust tube sheild up. All of this takes a few minutes and gives you plenty of clearance for the 1.450's.
BA APEX
go 144
1.375 - 1.380 max with no modifications
1.450 if you mod you protectors
AIRWOLF
Guest
192
MajorGasAttak
ONE, right in the middle. I'm on a budget!
