oldguy2
- Jan 16, 2012
- Saskatchewan, Canada
- 2010 RS Venture 2006 Apex ER
- Fort Qu'Appelle
After removing the side panels a couple times, The heads on some of the screws/bolts have stripped. I ended up cutting a big slot in 3 of them and put them on the bottom. Anyone else have this problem? I even used a Snap-On screw driver.
- Jun 28, 2004
- Clinton, Wi.
Other's will chime in and say that you need a #3 bit. I tried one and didn't like how it fit. I've since found a standard #2 with the tip ground slightly flat works perfect. Haven't stripped one since doing this. Hope I helped ya'!!
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
oldguy2 said:After removing the side panels a couple times, The heads on some of the screws/bolts have stripped. I ended up cutting a big slot in 3 of them and put them on the bottom. Anyone else have this problem? I even used a Snap-On screw driver.
There is a post in here somwhere that I posted about the same thing last year.
Long story short, I purchased some regular bolts (octagon head) which I believe were off a Phazer?
Sorry, I don't remember the part numbers or who even told me about doing it, but it does work great!
(I'll see if I can find it?)
- Jun 28, 2004
- Clinton, Wi.
Good point Irv. My 2011 Apex XTV has hex head bolts along the bottom edge of the side covers. Should be a readily available part!!
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Viper_Dave said:Good point Irv. My 2011 Apex XTV has hex head bolts along the bottom edge of the side covers. Should be a readily available part!!
Found it Dave
(Includes part numbers too)
http://www.ty4stroke.com/viewtopic.php? ... 4c1b0bf5a3
Phantom
- Apr 2, 2004
If you use the driver provided in the stock tool kit it fits the screws perfectly and does not strip them.
YammyRX1
- Jan 26, 2009
- Milton, on
- 2003 Yamaha RX-1
After stripping a couple with the impact driver I only use hand power now. For the hard ones push down on the butt of the screw driver as hard as you can making sure that it is dead straight and use the other hand to turn. I stopped using Loctite on these as they never seem to be loose when you go to remove them.
Glenn
screws
HI
I used to use a #2 Pozidrive screwdriver worked great for me. One thing don't over tigthen them
when you install them back.
HI
oldguy2
- Jan 16, 2012
- Fort Qu'Appelle
Thanks for the help and ideas.
buddah
- Apr 14, 2003
- Wetmore, MI
- '17 Sidewinder B-TX LE
Phantom said:If you use the driver provided in the stock tool kit it fits the screws perfectly and does not strip them.
You've posted this twice now.......just wait until you have arthritis in your fingers and then recommend that sh**..........i.e. some of us need something we can actually grip....
