Super duty idlers wheels!! Larger bearings and will run on studs!!
sabrecat
Vendor
JT Products has the 5.50 - 5.63 inch diameter idlers wheels back in stock for now. We use the two times bigger 6304 bearings for wheels that are on a wheel mount. If your model have two of the idlers on a shaft instead of a wheel mount we have the stock size bearings for that spot. We use the SKF 6004-2RS/c3 quality bearings for this wheel so it will last long time. The idlers have a wider contact area and will run on stud heads without problems. Made from the same material that out stealth kits and they will go over 10,000 mile without problems. The cost is about the same as the factory wheels at $40.00 ea. Call to place order.
8105450066
Todd
8105450066
ToddView attachment 157961
Do you have a stock part number to cross reference with?
