yamiboost
- Feb 17, 2008
- Labrador,
- 15 SR Viper MTX Hurricane 300hp kit
Fx Nytro Drag Sled 25psi + Boss Nos
Hi guys i recently purchased a snow performance meth kit for my supercharged attak and i was wondering if anyone has pictures of this kit installed. There are no sleds with this setup in my area so any tips for the install would be great, also if anyone knows where i can buy meth in newfoundland that would be great too but i'm thinking i'll have to go with windshield wash.
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
methanol is available at NAPA
PN # 545159L20 4LTR $8.99
yamiboost
- Feb 17, 2008
- Labrador,
Thanks there is a NAPA store in Quebec only 3 hours from here i'll give them a call.
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
- None, looking now!
Here are a few...
I am looking at the same set up. Please post your install pics as I could also use the data.
yamiboost
- Feb 17, 2008
- Labrador,
Here are a few pics of how i have everything mounted so far the meth have been working great its nice to be able to gas up at the pump this year. I had the meth installed the same day as my new camoplast intence 1.5'' track last year i was running the ripsaw 1.5'' after my first ride i had to add 3 washers to each clutch weight to get the rpm's down. Would this be from the track change or the meth?
The led is just in front of the gas cap
This is the worst part i lost my storage
BenderSRX
- Nov 29, 2006
- Constance Bay Ontario ( Ottawa )
- 2013 Yamaha Nytro RTX
Hi Yamiboost nice sled. How much boost are you running with the meth?
yamiboost
- Feb 17, 2008
- Labrador,
around 12-13psi
meth is hard to come by around here so i'm using windshieldwash seems like most guys are on here. Man i wish i would of had the meth last winter what a save on $
HURRICANE
- Oct 17, 2007
- Prescott Ont.
- www.hurricaneperformance.ca
- 20 washer fluid works great.Thats what all the Hurricane meth kits run on
Kevin Garceau
Meth may be easier to come by than you think. Its used in a lot of stuff.
Hydrite Chemical has it, I was buyin g 99.99% for 69 bucks for a 55 gallon drum. It has went up some.
Right now I think 55 gallons is about 125 bucks. I wish you guys were closer, I could get you a bunch. I have some contacts with VP racing fuel, if anyone is interested shoot me an PM and I will see if I can locate a distributor or fellow drag racer up your way that has contacts for it.
yamiboost
- Feb 17, 2008
- Labrador,
HURRICANE said:- 20 washer fluid works great.Thats what all the Hurricane meth kits run on
-20? i was using -40 washer fluid mixed with a little water i'm not sure if -20 will be good enough for here lately our temp has been in the -30+ range although today it was only -5 but in a couple days it will be back in the -30's again so will the -20 fluid be good for that? I don't know much about it but i know with antifreeze if you mix it for -18 it won't hurt but not sure about washer fluid. On the down side i was for a ride this evening and i noticed my led did not light up so i headed home thinking there was a problem with my pump but there wasn't the led is blowed anyone know where i can get a replacement?
HURRICANE
- Oct 17, 2007
- Prescott Ont.
We stock all the components needed for meth injection
yamiboost
- Feb 17, 2008
- Labrador,
Big thank you to HURRICANE for replacing my led on warranty.
Kevin Garceau
Kevin Garceau said:Meth may be easier to come by than you think. Its used in a lot of stuff.
So far I have gotten this response.....
I am in Ontario, I have been buying mine from Univar, they are based out of Toronto. Last season I was paying $146 for 45 imperial gallons, if I took 5 drums at a time.
Kevin Garceau
Here is another that chimed in.... Dave, right near you!
I live 60 miles from Prescott.Methanol can be bought from W.O.Stinson and Son in Ottawa,Ontario. 1-800-267-9714
