Supercharged Phazer mtn. lite fuel milage???
sci
I am about to get my Kit from MPI what should I expect for fuel milage after it is installed?
Josh at MPI told me I was the 10th person to purchase I still havent recieved mine.
If the milage matters you should not boost it.
SC suck fuel, turbos are better but at WOT they all suck fuel at a great rate.
If you double the HP you will use more than double the fuel at WOT turbos are usually not to bad at partial power SC are just bad on fuel period.
