Supercharger Clutching
YamerHammer
Saskatoon, SK
I have the ulmer stage 2 clutch kit and have been emailing him for month with no reply.....what can you say when your that good your busy man......anyway does anyone have a clutching setup for 10lbs of boost and around 1200ft they could Share with me please.
Do you have the custom helix or shockwave? weight, driving style? Not really a specific answer unless someone knows these things.
Here is what I have on my Nytro that runs 9 psi of boost and a 24 tooth top gear.
Bottom 4 washers and a tungsten weight.
Mid 2 washers only
Tip 3 washers.
Seams to work, however I have only rode alittle on this setup due to lack of snow.
My riding style is agressive, weight is 180 and I have ulmers custom K helix, don't know the degree of the cut though.
Mid 2 washers only
Tip 3 washers.
What is your base weight?
55 Grams or 60 Grams?
It is 55. The sled works really good with this set up. I might add one more washer to the tip, but it rocks!
