supertech st7317 oil filter the correct one for nytro xtx
brooklyn mi
Will the st7317 fit the nytro xtx or do they make a shorter one ? and if so part# would be appreciated. I see its longer but I have the roest skid plate.
You can run into a problem running a longer oil filter with the stock skid plate. Over time the stock plate gets bashed in and then rubs on the longer filter creating a hole. The aluminum Roest plate shouldn't have that issue.
Thanks I just found the oil filter on the search it looks like there wont be a problem with the roest plate thanks.
