08phazer
Hi, I need alittle help with my initial suspension settings. I have an 08 Phazer, I weight 190 and ride fairly hard on hard packed, usually bumpy trails. I have the torsion springs at the highest settings and the front shock spring in the middle setting. The front shocks are one setting from thier stiffest setting. I shortened the limiter strap two holes to cut down on ski lift. I ride mostley with Ski-Doo revs and seem to be getting beat up alittle more than they are. I don't believe I bottom and the ride is stiff compared to the revs. Any suggestions would be appreciated.
Does it bottom out if set at lowest settings all shocks?If not then do that.If it does then go up with springs.I assume you dont have the rebuildable clicker shocks.
Weapon X
Find your self a mogul section near your house or drop point, and bring the tools neccesary to make adjustments. Then back off adjustments in small increments like spring tensions and shock clickers.
akquad12
- Aug 20, 2007
My brothers got a 04 rev x package and it rides way better just cruising over the bumps but when we get on it in the nasty stuff it doesnt ride as well. I dont think your going to get it set up for cruising and bump riding. So I'm always standing up.
Me too for anything over 6" at least.
Weapon X
I set my unit up for the rough stuff and once its there its good all over for me.
- 6K
