I was looking at my son's 07 Phazer (standard Model). Suspension is set on stiffest settings(from factory). He weighs about 150 lbs. I think I need to soften it up. I am going move the spring cam to the middle setting and set the front springs to middle setting. Is there a trick to moving the front adjusment, this is the type with the notches.It woan't turning easily. I also noticed the limiter strap was all the way in the top hole. Should I adjust this also?
Any suggestions would be appreciated. He's not a real aggresive rider.
Raising the sled off ground makes it easier to turn those adjusters.But I would leave them alone since sled will bottom out alot if rear is set on soft.Strap is probably to tight but might not be bad to start there for a bit since it will help stability but make steering a bit hard.
hi suspension is soft so i would leave hard but if your son finds sled tippy and darty you can put both spacers on ski on inside to widen stance and also flip rubbers on ski to change ski approach angle i got yhis info from others on forum who know better than me. but it works
