2stroken
I need to do the reverse oil pipe change on my 07 MTX. At the same time I am going to put on a 1.75 cut down track. The service manual shows what looks like an oring, seal and snap ring that needs to be replaced. Anyone got the part numbers for these? Anyone done this and reused them without issue? Sled has 3000 miles on it.
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
- 2007 Phazer GT 136"
The o-ring and seal would probably be fine but the snap ring that retained the disk should probably be replaced.
2stroken
Thanks, Any one got the part numbers? I will probably just order all 3 items, in case the seal appears torn. I haven't done any digging yet.The o-ring and seal would probably be fine but the snap ring that retained the disk should probably be replaced.
Snowmixer
- Oct 29, 2010
- Snohomish, Washington
- 2007 Phazer Mountain Lite
2008 Phazer MTX
2012 Arctic Cat M800 153
Circlip: 99009-52500-00 (Item # 4)
Oil Seal: 93102-35010-00 (Item # 3)
O-Ring (large): 93210-62269-00 (Item # 7)
O-Ring (small): 93210-25071-00 <----- This smaller O-ring goes inside the small spacer that rides on the drive/track shaft and seals against the 'oil seal' noted above. (Item # 5)
This would probably be a good time to check and regrease/replace the bearings as well, since you'll have them out already.
2stroken
Awesome thank. I definitely will check the bearings, sled only has 3000 on it and trailered/stored inside, so I suspect they are in pretty good shape.Circlip: 99009-52500-00 (Item # 4)
