Swapping track on phazer
2stroken
Western Michigan
I need to do the reverse oil pipe change on my 07 MTX. At the same time I am going to put on a 1.75 cut down track. The service manual shows what looks like an oring, seal and snap ring that needs to be replaced. Anyone got the part numbers for these? Anyone done this and reused them without issue? Sled has 3000 miles on it.
The o-ring and seal would probably be fine but the snap ring that retained the disk should probably be replaced.
Thanks, Any one got the part numbers? I will probably just order all 3 items, in case the seal appears torn. I haven't done any digging yet.
Circlip: 99009-52500-00 (Item # 4)
Oil Seal: 93102-35010-00 (Item # 3)
O-Ring (large): 93210-62269-00 (Item # 7)
O-Ring (small): 93210-25071-00 <----- This smaller O-ring goes inside the small spacer that rides on the drive/track shaft and seals against the 'oil seal' noted above. (Item # 5)
This would probably be a good time to check and regrease/replace the bearings as well, since you'll have them out already.
Awesome thank. I definitely will check the bearings, sled only has 3000 on it and trailered/stored inside, so I suspect they are in pretty good shape.
