BFS
- Jan 26, 2015
- 2016 LTX-LE
Red/White
Looking to remove my sway bar to either change bushings or clean and lube to stop squeak that was there last year. When you remove the screw, covers and bushing is the bar under any pressure or will it stay in place?
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
No pressure at all, not sure if your ever going to get rid of that squeak, I've tried many different lubes and even plain greese, work's for a few rides and them back to its old squeaky self. I finally #*$&@ canned my swaybar but i went with a 38" front end too.
Froggy
- Apr 29, 2016
- Kipawa,Quebec
- 2020 Winder LTX SE 17600 km and counting
2016 Viper LTX LE 23986 km sold
2015 Viper LTX DX Wife's 22500 km sold
2010 Vector LTX GT 25000 km sold
2024 SRX Leftover 3700 km
Mine broke last year and I changed it myself when the dealer provided it under warranty to me as they were too busy to get it done in time. Takes some twisting and turning to get it in or out from the left side only.
BFS
- Jan 26, 2015
- 2016 LTX-LE
Red/White
Thanks for the info, I’m only going as far a removing the covers and seeing what I find with the bushings, clean and try some kind of low temp lube. Anybody use something that has worked over time??
Studroes144
- Oct 30, 2013
I too just mark that down as one of the things I give a quick shot of spray lube to after every few rides.
savageman69
- Apr 21, 2014
- 2014 arctic cat zr 7000 limited
i took mine out for squeaks...turns out it was my outer tie rod ends and still squeaked lol
BFS
- Jan 26, 2015
- 2016 LTX-LE
Red/White
Savage, what did you use to get rid of the squeak?
savageman69
- Apr 21, 2014
didnt find out it was tie rods till end of season so havent tried anything yet.....anyone who pulls the sway bar beware of major body roll change i ended up lying it over on the road last year with my sway bar out and it cost me a bunch of money in cosmetic damage...after 5800 miles with the bar in i wasnt prepared to the difference with it outSavage, what did you use to get rid of the squeak?
I shoot mine with Maxima chain Lube. The waxy stuff. Seems to last awhile.
Studroes144
- Oct 30, 2013
Yup I use a klotz chain lube on mine, same with tie rod ends.
