sway bar to be or not to be
sissy
Sweden
apex gt
hi all apex gt 07 stretched to 144 tipped rail extensions i run transfer rod full /max and limit strap full loose ride 95 percent off trail and love the floaty light front end the problem i have (even when 121 and factory settings) is getting inside ski to sink in deep snow to carve it take all my weight (220 lbs) with both feet on inside board to haul it on its side and if i let of the gas even a little iam high side over the bars
and side hilling is a joke it wants the down hill ski on the snow so climbing out of ditches is near impossible would removing sway/stabilizer/anti-roll bar help if so any advice on spring pre-load and clicker settings (gytrs) would be great i query the sway bar as my other much older skoter (non yamaha )is a widetrak with huge 10 inch skis and it craves real nice even with fat skis but has no sway bar !!!!!
answered this myself;;;; slid sway bar out (2 minute job) front shoxs as before 10 clicks rebound 6 clicks compression and zero preload on springs(skis off the floor) and out for test drive wow wow wow 3 mins up skoter trail rough as hell like cross track and into open flatland about a metre of soft snow and whooping doughnuts like a 500 2-smoke rode some rough terrain with side hilling and ditches haha new machine its like jumping from a big sports motorcycle (r1 e.g) onto a supermotard if you want go kart like handling on trail and limited deep snow ability/agility leave it in sounds like a joke but if you want fun whip your rod out
there you go.. ride a little stiffer, but much flatter...:4STroke:
