sledneck07
- Jan 15, 2008
I was wondering if anybody here has tried removing the sway bar on their phazer. What would the pros and cons be to removing the sway bar?
I feel taking them off would be better for jumping it.
You will need much stiffer springs if you take the sway bar out.sledneck07 said:I was wondering if anybody here has tried removing the sway bar on their phazer. What would the pros and cons be to removing the sway bar?
Yamahax98
I took myne off and it helped out a lot it dives and drives threw corners better than before and helps out a lot for side hillin and ditchin.
ecopter
Don't forget there's four positions for the stock sway bar to be put in. I'm not sure if it's covered in the thin owner's manual, but it is in the Service Manual.
Jon
Jon
fletch83
would you be able to post the positions?
Phazed-Coug
I didn't think the bar was adjustable, but I checked my service manual
Only the GT VT(Venture) and MP are adjustable..
The Base, FX, and Mountain are not.
The very top image(that is cut off, is the A(from the key PZ50/PZ50FX/PZ50M))
ecopter
Yep, that's it.
Jon
Jon
xc_phazer137
let me know what you think of the differance in tention.
