RX-1ND
How many of you guys have removed your sway bar and liked it on the RX-1 Mountain?
TurboVector
Depending on how my Vector feels, I'll probably experiment with disconnecting the swaybar. My last sled didn't have a swaybar but every other one did.
Climbmax
Had it out with wide stance and 151 and put back in with narrow stance and 159.......but you decide.
CM
CM
Kachess
I rode for 2 years with it in. Finally decided to try it out when we had some really deep snow. Thought it would help with the carving, and it did. Alot. No longer "rides on rails" on the trail, but is not bad. The improvement side hilling and carving is drastic enough that I'm not putting it back in. I have the Holtz "wider" ski stance.
BlgsRX-1mtn
- Apr 16, 2003
- Billings, MT
- '03 RX-1 Mountain LE
I pulled mine again now the the wife will have her own sled. Riding 2-up 80% of the time was not fun without it last season so I will see this season how it works.
RX1CO
- Oct 20, 2004
- aspen, colorado
- www.frontlineimage.com
I just took mine out the other day, and rode today without it, and i'll NEVER put it back in. You can lean into the hill now while side-hilling... it's not out of hand in the bumps, and cornering, you can actually lift the OUTSIDE ski if you're hauling enough #*$&@ and lean hard enough... YEEEE HAWWW.... !
First ride of the season... 1.5ft of POWDER!!!
