maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
look at these
I had them in my Viper, and they came with me to the warrior.
http://cgi.ebay.com/ebaymotors/Xenon-HI ... enameZWDVW
maxdlx said:look at these
The price seems right! I paid at least double that for my Silverstars.
Yamaha 40th
rock said:The Sylvania Silverstar part # is 9003 and I picked mine up at Walmart. Put these in and set your sled next to one with stock bulbs and marvel at the upgrade. What makes it even more impressive is the fact that the stock ones aren't bad.
Question do I need the one with the dual element or two of the "fog" lite bulbs?????? per the local Auto Zone they show both and the are only $9.99 each does that sound right????
You need H-4 or 9003 bulbs, they are dual filament.
Sounds like you are looking at H-3 bulbs, wrong ones.
Pureadrenaline
- Apr 6, 2005
- SW Michigan
- www.myspace.com
Tork said:The worst thing about the 06 headlight is there isnt any overlap between high and low beam, hi is way up there. I was thinking a bulb with a little different focal point to the 2 beams could help with that.
Do the silverstars help that problem?
Not really, we have had the stars in our Gt for two years and they are well worth the $, but I still find myself flipping between high and low to see the blind spots.
Yamaha 40th
watersuper said:You need H-4 or 9003 bulbs, they are dual filament.
dosen't say anything about H-4????
http://www.autozone.com/R,APP64100/vehi ... Detail.htm
Those are the right bulbs. The Silverstar Ultras are better if you want to upgrade.
Bigwin
I read some of you are paying $3.50 a gallon for gas that converts to $4.20 imp... per 4.5 litres of fuel per gallon.. get a load of this where paying $1.14 pr/litre xxxx 4.5 ltr/prgal =$5.13 pr/gallon imperial..Id stay at home..
Yamaha 40th
watersuper said:Those are the right bulbs. The Silverstar Ultras are better if you want to upgrade.
so these are the "stock" bulbs????
Yes. I,m not sure if it is the same brand though.
For a pair you are looking at $20. Apair of Silver Star Ultras are ~$34. A lot betterlight from the Silver Stars. IMHO.
The Ultras seem to last longer than the regular SS.
berge75
Bigwin said:I read some of you are paying $3.50 a gallon for gas that converts to $4.20 imp... per 4.5 litres of fuel per gallon.. get a load of this where paying $1.14 pr/litre xxxx 4.5 ltr/prgal =$5.13 pr/gallon imperial..Id stay at home..
Thewhitedogg
Well, took everyones advice (majority rule) and put in a set of the silverstar ultras. $49 at auto zone, regular siverstars were $37. Part numbers were #9003 for the standard and #9003 or H4 for the ultras. Cant wait to try them at night. Sure are alot brighter white than the stock.
K guys so which is the right # to buy for bulbs H4 or 9003 or are they the same thing thanks in advance
Tom
Tom
BigMac
- Jun 27, 2004
- Brainerd Lakes area, Minnesota
MUSKOKA APEX RTX 07 said:K guys so which is the right # to buy for bulbs H4 or 9003 or are they the same thing thanks in advance
Tom
You'll see 'em when you go to AutoZone. H4 is the socket type, they'll be labeled Silverstar Ultras 9003
Pureadrenaline
- Apr 6, 2005
- SW Michigan
- www.myspace.com
Thewhitedogg said:Well, took everyones advice (majority rule) and put in a set of the silverstar ultras. $49 at auto zone, regular siverstars were $37. Part numbers were #9003 for the standard and #9003 or H4 for the ultras. Cant wait to try them at night. Sure are alot brighter white than the stock.
How do you like the Ultras? When I bought my silverstars they hadn't come out with the Ultras yet.
thanks,
-pure-
- 13K
