Update 1-12-06 I hooked them up i got 4 ohms to from them i wired them together and they havent blown fuses or anything and are fairly warm but not like the 03 grips
did you wire them to the stock yammy harness so you can use the stock switch for up and down , i did this with one wire on the warmer and it worked o.k till one quit working now but i woundered if it would work better to have both wired together so both elements are heating
