Robbyb55
- Feb 8, 2009
I have read many posts about starter replacement and am totally confused. Some people say stay with OEM but then I read that OEM has magnet issues hence reason for failure. Aftermarket starters vary in price dramatically. Does anyone have a recommendation for a quality aftermarket starter? Many articles state concerns on aftermarket durability issues but if the OEM units are failing what is the difference other than initial price? My new to me sled is a 2006 Vector GT and first 4 stroke.
DB electrical, Niche, Rare electrical, which is better?
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
OEM only.
RobX-1
- Coldwater, OH
When it comes to electrical components like the stator I replaced, I tend to agree with Teamblue4 and stick with OEM. However, when the starter failed on my 08 Apex, I opted to go with one of @hibshman25 of Barn of Part aftermarket starters. The ONLY reason I opted to go with an aftermarket starter was due to the relative ease as to which it was to remove/replace the starter on the Apex. Although I have not had any issues with that aftermarket one, knowing the work involved with replacing the starter on your Vector, I would probably lean towards OEM. Maybe give him a call to see what he recommends.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Grizztracks uses rick starters.
After Market Motorsport Parts from Rick's Motorsport Electrics
Aftermarket Motorsport Electrics parts for motorcycles, dirtbikes, atvs, motosport vehicles manufactured and distributed by Rick's Motorsport Electrics
ricksmotorsportelectrics.com
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
The starter I just replaced with in my friends Venture had been in there for 18 years without issue. That’s pretty good I think. Maybe quality was better back then?
Robbyb55
- Feb 8, 2009
I called a local Yamaha dealer today and all yamaha starters are on backlog until end of December. He is pushing aftermarket but has to order it. None in stock. Sounds like there is a high demand for starters currently.
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
Barn of parts can get you a good used one or new after market and he a site sponsor.
Robbyb55
- Feb 8, 2009
DBelectrical has a starter #410-54116 that they say fits my machine but they reference Yamaha# 8GL81890-00-00 . Looking at yamaha replacement parts the number I find is 8GL81890-01-00. Does anyone know what the difference is between the 00-00 and the 01-00 units?
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
There is a new OEM one on Ebay in CanadaI called a local Yamaha dealer today and all yamaha starters are on backlog until end of December. He is pushing aftermarket but has to order it. None in stock. Sounds like there is a high demand for starters currently.
RobX-1
- Coldwater, OH
Not sure what you used for looking up replacement parts but when I looked up part# 8GL-81890-01-00, comes back as the starter for just the 2023 Sidewinder whereas part# 8GL-81890-00-00 comes back as the starter for a plethora of Yamaha snowmobiles like the Nytro, Venture, Vector, and older Sidewinders that span several years models.DBelectrical has a starter #410-54116 that they say fits my machine but they reference Yamaha# 8GL81890-00-00 . Looking at yamaha replacement parts the number I find is 8GL81890-01-00. Does anyone know what the difference is between the 00-00 and the 01-00 units?
Robbyb55
- Feb 8, 2009
Thank you. This is very helpful.
Robbyb55
- Feb 8, 2009
I found the 8gl81890-01-00 number on Yamaha Parts Nation. Just checked it again and this is what is listed. Checked other parts site and they list the 00-00 number. That is why I was concerned.
RobX-1
- Coldwater, OH
It would appear that 8GL-81890-01-00 superceded 8GL-81890-00-00 and that is what the '-01' is indicating; it's the next revision of the previous part number of 8GL-81890-00-00. More than likely, that is why Parts Nation only shows results for the 01 (ie. it's the only current part number) whereas others like Partzilla show both. Hope this helps.
I also think if using aftermarket to go with Rick's, but I can't honestly say for sure which is the best quality.Grizztracks uses rick starters.
Aftermarket Motorsport Electrics parts for motorcycles, dirtbikes, atvs, motosport vehicles manufactured and distributed by Rick's Motorsport Electricsricksmotorsportelectrics.com
