vogelm1
Just picked up a Morgan Carbtune and plan on synching the carbs on my '07 Vector GT. See there are several threads on doing the 4 cylinders - just wondering if the process same...does the adjustment screw cause one carb to go up/other to go down like on a 150? Or from my quick look under the hood, it appears that there are two screws, one for each carb #2 and #3.
Also, what do you do with the vacuum lines once you disconnect from the carbs? I assume the engine will quit running once the carbs run dry because the vacuum lines run the fuel pump? Thanks guys!
