mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
Where could I get specs on this box?
Where could I get this?
thank you
thank you
Yakuza
Hi, you could PM Mitch here. His forum name is Synergy.
Yakuza
I think this is his tel no. 1250-833-5724.
summitking
mmmkokanee
any idea on the cost?
summitking
sled
750 canadian
750 canadian
Yakuza
Summitking, has Mitch hooked yours up?
summitking
sled
No not yet. Hes been really busy so we are going to do it either later this summer or early next fall.
Yakuza
Cool...keep us posted.
mmmkokanee
will this work on an rx1 with a bender stage 2? I've emailed a couple times and got no answer from them.
summitking
timing control
Yes synergy has a timing control box for the rx1 sleds
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
- None, looking now!
Am I reading this correctly....this box would allow a guy to run up to 12lbs of boost on pump fuel without head gaskets stacked? Is that really safe? Sounds scary.
-1CS
-1CS
turbo mark
looks like 12lbs with the complete synergy system not with just his controller. i think!
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
turbo mark said:looks like 12lbs with the complete synergy system not with just his controller. i think!
The way I read it is with any turbo OR Supercharged sled. My impession is is, bolt this thing on, retard the timing 2 degree for every lb, and put in pump fuel and go....?????
