Nytro-glycerin
- Dec 13, 2014
- 2010 Nytro XTX Black edition
Looking for a link to a tried and true light for the back of my XTX, so I can free up the top of the tunnel.
Also, does anyone know of a factory way to extend the light wires? Not sure where the wire connects up at the engine end of the sled, maybe I can replace it with an MTX cable for the extra length? That way I can keep my stock set up in case Id like to go back...
Thanks!
Thanks!
Dr. FeeLGooD
This requires no splicing, cutting or drilling and use factory light. Just a little hackish, but I am ok with that.
http://i.imgsafe.org/765ae77eba.jpg
TLM
- Jul 19, 2014
- Hortonville, WI
- 2012 Nytro xtx, oft relocate, oilite bushings, comfort clutch, tunnel block, tailight relocate, cr10EK plugs, copper donuts, tuner skis, Grizz Tracks gusset kit. Excell x wheels. Mo-Flow console vent and curved vents.
I relocated my stock light to the rear of the tunnel. I didnt need any extra wires or splices. You do have to re-route the wires though. I had mine go through the tunnel under my seat. I riveted some small sections of aluminum square tube underneath the tunnel to carry the wires to the back of the tunnel.
pedros83
- Nov 19, 2015
- Blackstock, ON
- 2010 Nytro XTX
Yep x2. No splicing factory harness is long enough if you re route under the tunnel like mentioned above. I used a piece of black garden hose and zip tied it to the tunnel protectors and then drilled a hole behind the mounting location for the wire to come througg for the tailight
msgt van
- Mar 21, 2014
- Kasota, MN
- 2008 Apex LTX
I routed mine through the channel in the running board.
DSimps10
- Oct 10, 2014
- Oxford Michigan
- 14 Nytro XTX
This is a light I got, it's made for a trailer I found it online at a trailer supply website, used the stock plug and just spliced this light into it. Rerouted the wire into the square hole where the rtx light cover would be and used a PVC like tube to run the wire under the tunnel
Sent from my SM-G935V using Tapatalk
