Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
- www.jannettyracing.com
I recieved a lot of requests for these so I decided to put them in to production.
Geared toward the RX1 Turbo/Supercharger and mounts on the steering column.
You Get Breather/ oil separator box, #12 hose, 2 Clamps, K&N Breather filter, rubber gromet, and 3/4 aluminum tubing, to weld on bottom of box in desired location.
We also can weld on the tube for you if you know where along the bottom of the box you want it.
I recommend Cutting the 90 degree fitting in the crank case so it points up Vertical for drainback.
Price is 99.95
Ted.
Price is 99.95
Ted.
wantboost
how does it bolt to the steering.just trying to get a idea of where to weld the tube on.
Sapling
High jacked!!
ProstockBenji
- Feb 24, 2005
- Leamington, Ontario
- www.doublediamondacres.com
lightning Pro 's wont work with a front mount that charges from the mag side !Yamanator said:http://lightningprollc.com/?page=products/ventbox
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
Thanks Benji, Exactly the reason I built my own 3 years ago I had a Northeat turbo kit and the LP would not work for me.
LP is a nice peice but I don't need 3 nipples only 1.
Ted.
Ted.
rfabro
Will that box work with an MCX Phazer?
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
rfabro said:Will that box work with an MCX Phazer?
It will probably work on anything If you have a place to hang it so it will drain back to the crankcase.
Ted.
Yamanator
- May 5, 2003
- Oxford,Mi
- 2017 Sidewinder LTX LE
I was not trying to hijack anything, just letting the consumer know there are some other brands out there for specific applications. Ted, you are saying it will work with superchargers too.
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
Yamanator said:I was not trying to hijack anything, just letting the consumer know there are some other brands out there for specific applications. Ted, you are saying it will work with superchargers too.
I know for a fact they work on MPI supercharged RX1
Ted.
wantboost
ted how does it mount to steering.i don't see any brackets on the box.
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
wantboost said:ted how does it mount to steering.i don't see any brackets on the box.
Heavy duty Velcro, or you could weld on some tabs.
