I have a coolant gauge, boost gauge, and air fuel gauge that all need power. Were should I tap into for this power? Can anyone explain were the best location is or show me with a quick picture.
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
- www.jannettyracing.com
Re: Tapping into Electrical for Boost Gauge, Air/Fuel Gauge.
The best way would be to add a relay to power up your accessories off the battery, so not to over load any one wire in the electrical system.
Then switch the relay with your Key, If my memory serves me ( don't count on it ) I think the red with white stripe is switched 12 volts might be brown can't remember.
But test with test light or volt meter to find a switched 12 volt source.
FAMILYMAN said:I have a coolant gauge, boost gauge, and air fuel gauge that all need power. Were should I tap into for this power? Can anyone explain were the best location is or show me with a quick picture.
SPEED
Purchased a Painless Wiring fuse panel from Summit Racing and installed it on frame right above clutch guard comes with relay that activates three circuits with ignition and has three circuits with constant 12 volts. Gives you six independant circuits from sleds wiring harness, You run a 12 volt positive from battery to panel and ground panel to frame. Relay is powered from sleds fuse panel. I am running my Innovate gauge , face shield all power to boost gauge, parker knock box and digital water temp gauge ,. Gerbings heated clothing and led lights. It is working great.
Part # is PRF70207 price is 59.95
Need for Speed 2
same here painless fuse panel is the ticket for safety and does neat job.
Whhhooo I was hoping to spend more money
I will get the relay switch and do it up right. Thanks guys!
