Where to get power for air fuel gauge
BoostedBallz
Prince George
Where can I gat my power for my air fuel gauge that wont overload any fuses. I am currently hooked in to the power wire for the tail light but I am hooking that up so I need to find another location.
If its an Apex you can use the accessory outlet for powering the various gauges.
I tapped into wiring for the reverse system (I don't have reverse), for a 10-amp fused "key-on" power source, it's in the right foot well, see wiring diagram in owners manual... If you run a probe that's heated (innovate bosch probe) it draws a bunch of power initially to get the probe up to temp and if it doesn't get enough you'll get an error-8 code (supply voltage too low) in the display... I wasn't sure if the 2.5-amp Apex "accessories plug" would handle the probe and my intercooler fans initial draw without getting an error so I went that route.
Innovate Error Codes (page 21): http://www.innovatemotorsports.com/support/manual/LM1_Manual.pdf
