Janne339
Does it work well? Have there been any updates since it came out last season?
Its pretty expensive so looking for some feedback before I buy it.
sideshowBob
I have Hurricane tunes and closed loop...sled runs flawless.
Hammer Down
- Oct 7, 2016
- Loudon, NH
- Sidewinder STX-DX 2017
Apex XTX 2012
I have it haven’t noticed a difference and had an O2 sensor Failure. Save your $. I Run bundle tune 95% on MS16sm
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
def made fuel economy better, was 3 ltrs better every fill up than the 850 pol and skidoo same riding at 100 mile ride n fill
Hammer Down
- Oct 7, 2016
- Loudon, NH
Apex XTX 2012
little No fuel gains for me. Run with many winders stock and tuned all on big trips we are always within .5 gal of each otherdef made fuel economy better, was 3 ltrs better every fill up than the 850 pol and skidoo same riding at 100 mile ride n fill
sideshowBob
I don't know if the closed loop has had a positive affect on my fuel mileage it is so hard to tell with all the variables...it sure hasn't hurt the fuel mileage.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
NYTurbo
Have found closed loop to make fuel economy worse. We even compared two sleds same clutching, same exhaust, same tune, same day, same driving characteristics. Disable close loop and their back within a dollar of each other.
Janne339
Any better throttle respons?
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
Not what i was hoping to hear at all.Have found closed loop to make fuel economy worse. We even compared two sleds same clutching, same exhaust, same tune, same day, same driving characteristics. Disable close loop and their back within a dollar of each other.
I just installed the TD Closed Loop cause I wasn’t happy with my data logging showing my AFR’s and afterwards looking now I’m very happy it works wish I bought it sooner. It’s pulling more fuel then adding with my Maxspool17 tune which is everything but cams.
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
that sled prob had a bad wide band 02 as mentioned above, if using additives in fuel ... they will deteriate fast.Have found closed loop to make fuel economy worse. We even compared two sleds same clutching, same exhaust, same tune, same day, same driving characteristics. Disable close loop and their back within a dollar of each other.
NYTurbo
nothing wrong with the O2 and no additives
snowdust
Curious what temps you were riding in and also what your setup is. You run a 3" exhaust by chance?nothing wrong with the O2 and no additives
Doowithblue
- Mar 17, 2016
- Waterloo ON
18- RTX LE
I just asked Dave about fuel economy and he is seeing improved fuel economy from a ton of logging vs canned 3bar ss tunes.
