yukon yamaha
- Jan 30, 2008
- WHITEHORSE, YUKON CANADA
- 2008 nytro custom! 2014 viper custom
I am looking to see how many guys have a team roller clutch on their sleds..... What Helix are you running, track length mods and elevation.
I wanna try to tinker with one next year just hoping to get some feed back before I jump into it
Thanks guys
Thanks guys
09nytro
I'm running one...121 track
Red/Black spring
54-36-.46 helix
Heavy hitter
hole #1 .9 grams
hole#2. 1.7 grams
hole#3. 3.4 grams
Rpm's 8850
The base weight for the heavy hitters is 48 grams
Set up works great for me....hope this helped
Red/Black spring
54-36-.46 helix
Heavy hitter
hole #1 .9 grams
hole#2. 1.7 grams
hole#3. 3.4 grams
Rpm's 8850
yukon yamaha
- Jan 30, 2008
Wow I was thinkin starting my helix aT 77-55-46
09nytro
You could try that but it may be to much..I tryed. A 62-46-.36 no good went back then just foaled the weighs in
I for got I'm running the blue/green primary spring from team too
09nytro
Tom Hartman is really good with clutching too give him a call...that's who helped me too
Redbeard
- Oct 14, 2011
- IN
- 2012 Apex, 136 M20, PB80
2008 Vector, 136 M20, PB80
09nytro said:Tom Hartman is really good with clutching too give him a call...that's who helped me too
X2 with Tom Hartman. He pretty much nailed my clutching the first go around. The only thing I changed was the mass in the tip of my weights.
shadow44
09nytro said:I'm running one...121 track
Red/Black spring
54-36-.46 helix
Heavy hitter
hole #1 .9 grams
hole#2. 1.7 grams
hole#3. 3.4 grams
Rpm's 8850
Set up works great for me....hope this helped![]()
Notice any top end gains? What are you engaging at and what other mods are you running?
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Be sure you say which Team secondary setup you are running. The TSS-04 runs less helix angle than the new TIED setup.
Allen Ulmer is also well rounded with this set up and has some on sale right now. Allen is a very humble stand up guy so give him a call.
09nytro
I'm running the tss-04
No mods just a gear change 20/40
Pulls hard right. From the hole don't see any more on top Its the same as stock well maybe 5 mph on top not much I like the backshift it gives and upshift both are smooth
