mach9
I generally go with the most rebound I can get trying do keep the carbides digging as soon as possible. Then change compression to taste.
redrx1rkt
- Apr 20, 2005
- South Shore of Lake Ontario
- www.snowdevils.net
Just created a new post, but will ask here too...are all the posts above applicable to just the front shocks? The rear shocks on an RTX look totally different.
redrx1rkt said:Just created a new post, but will ask here too...are all the posts above applicable to just the front shocks? The rear shocks on an RTX look totally different.
These are directed at the Front Shocks... as far as the back, on the RTX Style fully adjustable... the compression is on the remote can and the rebound is the dial on the shaft.... if you have something different post a pic and I will explain.
redrx1rkt
- Apr 20, 2005
Mr. Sled - we got it figured out. Not the easiest things to do using two cell phones, with me communicating information. He has the compression and preload both set at softest settings and it is riding a lot better. Need some better (or worse) conditions to see how it holds up to bumps.
Thanks, everyone, for the help. Couldn't have done it without TY!
redrx1rkt said:Mr. Sled - we got it figured out. Not the easiest things to do using two cell phones, with me communicating information. He has the compression and preload both set at softest settings and it is riding a lot better. Need some better (or worse) conditions to see how it holds up to bumps.
Good news
tomseal6
- Aug 23, 2006
- Brevort, MI
- 4 strokes
clickers seems to work great 5 turns out on stutter bump trails
using factory or dealer set-up setting on the adjuster rings
