Enticer
I have a Warrior and I cannot get the results you get. I have heavy hitters, the rest is stock Warrior. Would you mind sharing your total set up? Springs, cam twist, gear, weights in the arms, etc. I am in a slow mode and need help. Thanks. Enticer
Ted Jannetty
Try this and let me know how it works.
Stock helix and spring at 6-1
Heavy Hitters,
1/4 and 3/4 allen in heel
7/16 steel bolt and thick washer in middle
3/8 steel bolt and thin washer in tip
That is it no other changes.
Keep in mind You need to get some miles on these before they really start to run good.
I have 770 miles on mine which is still low for total breakin.
Heavy Hitters,
