Marco Paradis
- Jan 27, 2018
- Dundee nb
- Two 2017 sidewinder
Maybe air lock ?
FrozenTows4
- Nov 6, 2014
- Brainerd Minnesota
- 2014 XF7000 Sold
2017 ZR6000RS
2018 ZR6000 El Tigre
- YOUTUBE
- FrozenTows1
How's it acting up? Trail conditions play a huge role. Last weekend, on one trail, I saw a consistent 158f/70c. Different trail 177f/80c. Another freshly groomed trail 195f/90c. Cross the lake and down to 165f/74c. These things can be all over the charts depending upon conditions.
Marco Paradis
- Jan 27, 2018
- Dundee nb
Marco Paradis
- Jan 27, 2018
- Dundee nb
80 f to 200 f ? When riding and it move real quick on the gauge
upei93
- Apr 27, 2008
- Dalhousie, NB
- 2015 Viper X-TX LE MPI turbo
2009 Nytro XTX
This was my sled...sled ran fine for first 10 miles then stopped to gas up and when I got going again the temp gauge would read normal 170f then all of a sudden drop to 20f and red cold temp light would come on...I would pull over turn it off then start it and go...did this a couple of times then stopped douing it for 6-7 miles (I was alone so needed to make it to buddy's camp) then it started again...Never overheated the temp gauge would flicker between normal temp and cold temp...ideas?
Turtle
- Feb 27, 2006
- Marathon, WI
'07 FX Phazer GT
Most likely it's a bad temp sensor. Had the same thing happen to me. Sled would be running normal temps, then immediately would drop to a cold temp. Which would then tell the ECU that the engine is cold and would limit RPM. Then it would jump back to normal temp and engine would run fine. Had this thing jump around on me while riding the sled. It would jump around so quickly it was hard to figure out what was going on. I tested the resistance on the temp sensor back in my heated shop. Shop was at 65 deg F, and according to the resistance conversion on the temp sensor, the sensor said it was below 30.
Got my temp sensor replaced under warranty. No issues since (that was 2 seasons ago).
upei93
- Apr 27, 2008
- Dalhousie, NB
2009 Nytro XTX
Thanks for the reply...exactly what is happening to me...forgot to mention limited rpm...and no codes right?
Turtle
- Feb 27, 2006
- Marathon, WI
'07 FX Phazer GT
Yes - limited rpm when the sensor acted up. That's because with the hosed up sensor, it tells the ECU that the engine is cold. On a cold engine, the ECU will limit rpm to just below clutch engagement.Thanks for the reply...exactly what is happening to me...forgot to mention limited rpm...and no codes right?
I can't remember if I had a code or not.
upei93
- Apr 27, 2008
- Dalhousie, NB
2009 Nytro XTX
Thermosensor Assy 8JP-H5790-00-00...this the one?
Turtle
- Feb 27, 2006
- Marathon, WI
'07 FX Phazer GT
Yep. That's it!Thermosensor Assy 8JP-H5790-00-00...this the one?
