yamahacat69
Buddy of mine got 16 viper turbo blue it up so he put a nytro engine in it now he tells me that the temp only goes up to room temp 11-13 degrees on the gauge temp light stays on no matter how long it’s running for
Any ideas out there thanks
did he put the viper sensor in it?
yamahacat69
What sensor u referring to bud
Temperature sensor
Temperature sensor
yes. unless you can confirm both are the same part # from yamaha.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
The temp sensor is located in the thermostat housing, so he would've had to use the Viper thermostat housing. Are you sure the coolant system is bled properly? Are the sensor wires connected correctly?
