stinx
I had the same issues in my 06 Attak. I diluted the coolant and have not overheated again. I have about 4000 miles on the sled since I diluted the coolant
blackattak
Nice Rumle:
Just do a search with me as an author. It is actually on this pge right now & there are a lot of good tips, hopefully my mechanic pays attention to them this time as I printed off thetopic for him. "First trip out...."
tuner
I added a rear exchanger this year with no problems in any condition, anymore.
Nice Rumble
How do you remove the black shroud to get to the rivets?
gitrdun
- Mar 15, 2007
- north of superior
- 07 Attak
Lift the back end up. Bolts are on the inside of the tunnel. I believe there are four. On the Attak anyway, I would think yours is the same.
ApexerER
I have overheated once this year and am interested in the rear cooler. Do you have to worry about studs hitting it or is that only on the Attak.
Thank you
Thank you
Nice Rumble
thanks gitrdun.
Nice Rumble
ApexerER said:I have overheated once this year and am interested in the rear cooler. Do you have to worry about studs hitting it or is that only on the Attak.
Thank you
I think as long as you use the bottom exchanger from Pioneer Performance you should be fine.
60/40 ratio of coolant to water should get you to how far below zero? Just so I know when adding water and using the tester this weekend.
gitrdun
- Mar 15, 2007
- north of superior
- 07 Attak
That would be -53 Celsius which is approx. -63 F.. 50/50 is -37 C which is -34 F.. This is all according to the manufacturer's rating.
SharkAttak
my 07' phazer over heated the same as my 06' attak until i got all the air out of the system and got the ant-freeze toa 50/50 mix with water wetter added, neither has over heated since
gitrdun
- Mar 15, 2007
- north of superior
- 07 Attak
Here's a little tidbit of nothing. As I mentioned earlier, 50/50 is good for -34 F, -37 C according to the back of the ethylene glycol jug written by the manufacturer. I just put one cup pure antifreeze, and one cup water in a jug, mixed it good and tested it, and got a reading of -20 F, -29 C. So, if this holds true with all 10 dollar ethylene glycol testers, then, your antifreeze is always better than you think.
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
The Apex cooler (bottom one in the above picture) from Pioneer needs no stud protection. It is small enough and mounts where your studs have zero chance of hitting it.
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
Two more tidbits, although this may seem obvious to most, when you are diluting the coolant mixture make sure that you add distilled water rather than tap water.
Also if you add ethylene glycol make sure that it is silicate free like what is in the sled from the factory.
Nice Rumble
Blue Dave said:Also if you add ethylene glycol make sure that it is silicate free like what is in the sled from the factory.
Good point Dave.
