Can anyone tell me where I can purchase these terminal ends the type they are.
They're for the ATM (mini) fuse box on my 05 RX1.
I have 2 blanks spaces and I would like to add two fuses.
Have you looked at Radio Shack, Auto - Parts Plus and Ace Hardware? Then once you find the connector, the question is will it fit in the fuse block?
I would probably just add some in-line fuses in the two new circuits. You can get spade in-line fuse holders at almost at any auto parts stores.
Sometimes, doing the job right is more difficult and expensive (e.g. getting these connectors out of Digi-key would most-likely cost a $25.00 minimum order.)
They might be available from Yamaha. Check with your local Yamaha service department or mechanic.
I know I was able to get the crimp-on fuse clips that fit the factory box on my XS1100 Yamaha from the dealer. They won't help you here as they use the old round style fuse.
