DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
This is an old thread. I've done the stage 6 upgrade since this thread was last active in 2021. But yes it would be a good idea to install the bigger pump for doing long pulls on the bigger tunes.If your going to be running 3000 feet WOT I’d put a bigger pump in it to be on the safe side.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
DMC, that's awesome!!!! The back & forth detailed testing & trying different mods, conditions, etc.Thanks. Have come along way over the years.
To know your particular boundaries and goals have brought you & us an amazing experience.
So very happy for you.....it's kinda like I was there....in a sense.
Ty..... Joe
Turboflash
- Mar 18, 2019
- Southern MN
Sure hope you're letting it cool off (coolant and oil temps) before next run. Nothing wrong with 3,000 ft runs but too many back-to-back without sufficient cool-off time might cause some "problems".This is an old thread. I've done the stage 6 upgrade since this thread was last active in 2021. But yes it would be a good idea to install the bigger pump for doing long pulls on the bigger tunes.
DMCTurbo
- Nov 12, 2005
Of course. I keep a close eye on everything.Sure hope you're letting it cool off (coolant and oil temps) before next run. Nothing wrong with 3,000 ft runs but too many back-to-back without sufficient cool-off time might cause some "problems".
