tether cord on 2015 viper
rx1 fern
thompson mb
which wire color are you cutting to put the tether wires into .thanks for the help .i think its better to cut into the main plug that you unplug to get hood off .this way i can put tether on the blue plastic opposite side of the seat warmer .thanks for the help
I went with the Cat tether so I wouldn't modify anything. Did have to relocate a couple wires though but it is factory stock parts.
thanks .figured it out .red/violet wire is where i needed to cut into .
Personally im not a big fan of splicing into a factory wiring harness. If your going to install a tether why not do a tether/ROV kit from OFT or Four stroke solutions its all plug and play with factory style connectors and no splicing into the harness
