Redbeard
- Oct 14, 2011
- IN
- 2012 Apex, 136 M20, PB80
2008 Vector, 136 M20, PB80
I read an article by Lakercr in the Tech Center on how to remove a jackshaft and bearing from an RX/RS/Apex. I followed the step by step procedure and the shaft and bearing came right out of my 2008 Vector.
I just wanted to say "Thank you again TY", and to all that have the taken time to answer questions and share info.
http://www.totallyamaha.com/snowmobiles ... change.htm
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
We sure have a great group of people on here.
Agman 57
- Dec 28, 2006
- Fostoria, Ohio
- 2018 Apex XTX LE, 50th Ann.
2018 Sidewinder LTX LE, 50th Ann.
2017 Sidewinder BTX LE
1992 V-Max 4 (Modded)
2002 ZR 120 G-daughter's
X2
There really is a great group of people on this site offering how to and heads up advice. The best way to say thank you to the site is by being like you guys are with VIP memberships!
TOMBOB
- Jan 20, 2011
- Saranac,Michigan.
- 2006 APEX ER
jackshaft removal
I have the same job to do on my vector. Do you have to remove the reverse gears to pull the jackshaft
TOMBOB
TOMBOB
grossman
Re: jackshaft removal
EDITING THIS BECAUSE I HAD A BRAIN FART AND GAVE BAD ADVICE AT FIRST.
The whole chaincase has to come off to pull the shaft. So the gears have to come out. To be honest though, it's really no big deal taking the gears off. What I did was as I took off each gear and shim, I put a piece of wire through the middle. I wired all hte pieces together in the order I took them off. That way, on reinstall I know exactly what gear and shim goes where and in which order.
My problem was that my '03 RX1 doesn't have that screwed on tapered bushing. It just has a press fit. I stared at the pictures for a while, compared them to my service manual then decided to take a sledge to the jack shaft (carefully and with a piece of wood). A few solid taps and it knocked the shaft free.
Now I can't quite figure out how my non-threaded bushing holds the jackshaft in place on re-assembly... i'm hoping it all works itself out when I get the parts.[color=Font Color] [/color]
TOMBOB said:I have the same job to do on my vector. Do you have to remove the reverse gears to pull the jackshaft
TOMBOB
Redbeard
- Oct 14, 2011
- IN
Honestly, since you're that far, just pull the chaincase / drive axle and replace the drive axle bearings too. Atleast check them.
TOMBOB
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
Sled Dog said:There really is a great group of people on this site offering how to and heads up advice. The best way to say thank you to the site is by being like you guys are with VIP memberships!
Agreed! I have learned a great deal from my fellow TY members. I feel that my Lifetime VIP Membership was a bargain to help support this great site!
Blue Dave said:Sled Dog said:There really is a great group of people on this site offering how to and heads up advice. The best way to say thank you to the site is by being like you guys are with VIP memberships!
Right on guys
Rockmeister
TY Advertiser
- Feb 7, 2007
- NE Indiana
- www.yamaheater.com
- 2007 Attak - LOVE my sled!!!
X 1000
