I have mine apart right now and have a couple questions. How do you get the jackshaft brg lock ring tight?? prt# 18 & 19. I have held the nut with a spanner wrench and tried turning the secodary to tighten but the locking threads just spin on shaft. It only goes so far finger tight and I cant get anymore on it. If I hold the lock ring the shaft just tuns inside.
Second is on the chaincase side. There is a washer under the top gear nut and it is cupped. prt#53 Which direction does the cup ( face. cup to motor ( or to brake )?
As for the side to side play in secondary clutch I had play before I started and hope it is there after.
