NY_SXR700
- Dec 30, 2003
- Webster, NY
- www.sohonetworksny.com
- 2001 SXR700
2006 Apex-GT
I finally had a chance over the weekend to tear apart the GT. I figured out what you were all saying about the alignment stuff (it's not spelled out as clear until you look at it). The down side is, I need to move my motor to the MAG side to lenghten the width between my PTO and jackshaft. From stock, I was able to get about 3 turns only and that is not enough. There is an internal collar on the 2 sided threaded spacer. After 2.5 or 3 turns mine was touching the frame (can't move any further). That is not enough to move my motor where I need it. So, where do I go from here.
Thanks,
Doug
Thanks,
Doug
