Thanks for tips guys BUT Still coding 30
APEX'N
Hi guys...thanks for the earlier tips...I am assuming it is air locked as well ... Leaned sled on about a 45 degree angle with the oil pan facing upward so the air would flow up ... left it like that for about 30 minutes ....laid it back flat and started it ....stalled after 20 seconds and coded 30 again????? I am really stumped on this one ...is there a way to get oil through all the lines with a little compressed air ...
Is there oil in it ????????????
Quit running it -- take it into a dealer . If it runs to often without oil-pressure you may do some damage. You already backfilled the oil filter gallery so there has to be more to it.
One last try take the oil-filter of (with the plugs out and in the caps grounded out) turn the engine over for 10 to 20 seconds and see if you can get oil
coming up to the filter. Also check the oil pressure sensor making sure that it works and the wires are fine. If it gets no signal to the computer it will do the same as if you have no oil pressure.
Yes there is oil in it ...lol it doesn't appear to be circulating as when I took of the oil filter there was vitually no oil in it ...maybe a table spoon .... I was now staring to think electrical ...I don't think it has a fuse ...where would I find the sensor...and how can you test it
