Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
I drive an F250 and an Escape.
Nytro40th
- Sep 19, 2007
- Amherstview Ontario
- 2014 SR Viper RTX SE
My dad works for Ford as well he bounces around plants, skilled trade. I think he is at nemac off lauzon
FxsX24
- Jan 20, 2007
- PitX Snocross track.Verona, NY
- pitxsnocross.com
well if the orig design was snox, it didnt need a holder for a belt
last minute addition
KennyCederstrand
I made my own.. looks pretty much the same...
TurboJamie
Just a quick note to avoid any real interfearance. The yamaha dealer put 2 v clips on Marks sled and we test fit the belt last night and it hits the side cover in 2 places.
Try to keep the clips to the inside of the cover closest to the frame. This avoids interfearence.
Sno-Xr
- May 3, 2005
- Clio (Flint), MI
- Nytro
Ahh, so you must work for Chrysler!! lolCrewchief47 said:I drive an F250 and an Escape.![]()
Sorry, couldnt resist!!
NyTrOMaNIaC
TurboJamie said:Just a quick note to avoid any real interfearance. The yamaha dealer put 2 v clips on Marks sled and we test fit the belt last night and it hits the side cover in 2 places.
Thanks for the heads-up TJ ! I'll be installing mine soon and I'll do that
Sierraspirit
Spare Belt Holder
The pic is not terribly clear. I used two clips and they worked fine. Just be careful of rivet length if installing two. Long rivets appear close to top of belt of secondary clutch. I used shorter rivets near the secondary and slightly longer ones up front near the primary. Has worked great so far.
TOOL BAG
THE BELT GOES IN THE TOOL BAG....... FOLD IN HALF AND ZIP UP BAG, IT THAT EASY!!!!!!
Mr. Freeze
It's obvious you haven't tried to get the belt out of the bag after a day of riding when the bag is under an inch of ice and the zipper is frozen closed. Placing it in the bag is that easy, getting it out is not. I would have paid to spend 5 minutes alone with the jack *** that came up with that idea the night I blew a belt and spent an hour changing it.
Nikolai
I finally did this after needing to get the spare belt out of the bag...impossible if the front is packed with snow.
Like mentioned above, keep your clips close to the inside of the cover. I used two and kept both on the far inside edge. If you put them in the middle the belt will hit the sidepanel.
For those people who are really perticuler order the ones off a 2006 nytro they are aluminium
Monster00
I think its becuase the Nytro is Yamaha's race sled. Racers don't need to carry around spare belts. I also think they didn't put the a/c jack in the front for the same reason, because its Yamahas race sled. Even though Yamaha did know (or I hope they knew) that people would be buying the Nytro more for trail riding rather then racing. They should of put both the belt holder and the a/c jack in but I think thats the reason IMOP.
Have had mine there since day one. 2200 miles later it's still there.Doesn't seem to have caused any problems so far.EsonPZ said:Maybe it can interfer with the air flow that is supposed to go trough the radiator and out the vents in front of your knees. (longshot)
Daranello
Suspended
Re: Another Idea
I like that Idea...and its only $9 and dont have to worry about your belt hitting rivits
nytro23 said:Or you cut two slots and use a velcro strap ( arctic cat idea ) instead of a metal clip.
