20/80
- Mar 25, 2010
- Nova Scotia
- 2016 APEX LE XTX
First of all this to me is a great sled, but there is a few things about the sled that I need some opinions on where it is my first Apex, first fuel mileage, I am getting around 13 to 15 mpg when driving between 30-40 mph on the trail and in twisty slow riding wooded trails, these are all not groomed trails, trail conditions play a role also holding it to the bar changes the mpg quickly also, next single shot suspension, I have the 146 1"3/4 backcountry track which is good in the deeper snow trails but I do find that it chews up the trail behind you, I have the updated shock and find it rides a lot better than the factory the Apex came with first, something I noticed about the single shot skid is in the choppy bumpy slow wooded trails the skid makes a clunking sound from the skid rebounding at times and can be a bit annoying, not sure if anybody else experienced this to or not, steering, I got rid of the factory tuners where I felt they were just to narrow for the weight of the sled in the deeper stuff, I run the VK pro skis now with ST on them and like this setup, did some testing today to see why the ST were darting from side to side in crusty snow, turns out my front air pressure was way to high I have the shocks set at 70psi now and has made a world of difference, one more thing I noticed this morning and has not happened before is when I went to start my machine the dash lit up and cycled but would not turn over, turn the key on and off a couple of times and then it finally turned over and started, it was not that cold out last evening so it has me puzzled? worked fine all day, your thoughts and experience with Apexes is more than welcomed. thanks
